Build FlyingWil's FZJ80 Build thread...
Outback Drawers, 80 Fit Kit, and Cargo Barrier
Well it's finally in, the Outback Solutions Modular Roller Drawer Systems.
I opted for the RD1045US and the RDRF1045US with the 80 Series Fit kit. It only comes in grey, but I really like how it turned out.
Install was fairly simple once I figured out how it was supposed to go, (read after 3 test fits) and following the instructions. It mounts using the rear two tie down points and the forward 3rd row seating latch on the cargo floor.
Here you can see it attaching using the third row seat latch:
It uses several fully sealed bearings that make it a "no rattle" drawer system.
The fit kit fit perfectly, and the side compartments unscrew using a large dial screw to not waste any space.
The slam latches are a higher quality than I was expecting, and seem like they will last a lifetime.
I opted for the the Roller Floor to be on the driver's side so that when the fridge is on top it will not block the rear view as much as if it were on the passenger side:
Again the fit is very good. I was concerned about the fit, and never should have been.
In addition to the the drawers I added a cargo barrier. Again another easy no drill installation. The top brackets are installed behind the OEM rear (3rd row) seat handles:
The bottom brackets are installed to the drawer modules.
(disregard the German Shepard Dog hair... I had a helper)
Here you can see the secondary bracket, the one on the left is a "catch" in case of an impact, the top also has impact zone created into the mount as well.
Here it is all installed:
Nice build!
Do you have ARB's part number for the cargo barrier?
Cheers
