Flushing my 97 tranny
Ok so ordered my amsoil ATF and swung by shop that has flushed my trannies on 3 other vehicles (drop pan, change filter hook up to machine and flush and refill with Amsoil) my 97 is the first 80 they have worked on and they look it up in their data base and say it says only to drop pan and change filter and refill. No flush directions. So did I waste my money or can this tranny be flushed and their database just not up to speed on 80's ?
Don't do any flush
. Just pan and oil
In the 80 forum we often refer to it as a "fluid exchange", replacing all the fluid with new via the transmission cooler lines. I did this 160,000 miles ago on my 96 FZJ80 with the A343F transmission, still shifting fine at 345,000 miles.
my bro had a truck w/200k on it. the
tranny worked fine, and shifted smoothly. the fluid was dark and smelled slightly burnt. he took it to a shop and had it flushed, a few hundred miles later the tranny died. coincidence? not sure, but i wouldnt risk it. conventional wisdom is that if you havent been flushing the tranny regularly (ever 30-60k) then flushing is more likely to dislodge something and cause a block and destroy the tranny than help anything.
just drain and refill.
Run a way from that shop! There is only a screen in the transmission, no filter. There is no filter to change.
Transmission mechanics will always tell you to never flush a transmission that is having a problem. It will flush out the dirty, gritty fluid that is full of used up clutch material. That floating clutch material is the only thing that is helping the tired clutch plates have any grab. Flush and put in new slippery fluid, transmission stops working.
As stated above, you should only flush a transmission if it was done on a regular basis through out the miles of it's life.
Ive allways been told that, I bought a 99 f250 that had 132,000 miles heavy towing. Never had the fluid changed.....it was black and nasty...changed the filter then flushed thru new filter......truck has 206,000 miles now ans shifts like it the day it was delivered (was my work truck so I have put every mile on it) .......98 crown vic same story....120000 did same thing now at 145000 and shifts like new.....I wouldnt flush before changing the filter tho
Im confused, everytime I google it I find what looks like a filter and have a wix one I ordered from amazon that says its for 97 landcruiser...it looks like an AT filter ?? I know the 80's used a different tranny the last couple years.....could that have a filter and the earlier one has a sceen ?
This has been cover many many times and best thing to do is to just a drain and fill every so often. Don't drop the pan because ther is no filter and only a screen and by dropping the pan you are more likely to introduce more dirt in than you are cleaning out. Also don't flush the tranny as it could be too much of change all at once, these tranny are known to like old fluid.
If ain't broken then don't fix it, just change oil slowly till it's more or less clear.
