Floating motor mount
65swb45
Elder Statesman
Website
marksoffroad.net
Under the category of ‘just when you think you’ve seen it all...’
Darn file rotated when I downsized it. That’s what I get for being file friendly! :p
Mark,
Is there supposed to be a picture? Or can we use our imagination?
The opposite side is probably flat as a pancake and that lower one is holding all the weight
i see the picture but not the issue
there is literally an air gap between the upper cushion and the bracket. Driver’s side is the ‘lift’ side, so it needs to be VERY tight against the torque. Obviously it is not. And the front motor mount is very broken as a consequence.
Mine isn’t that bad but it does rotate freely by hand. Can I load a couple washers under the castle nut and tighten? Today I may attempt to replace that front left mount that you sent me last week.
It should never rotate freely. And yes, 1/2” flat washers are an acceptable solution, provided the donuts are not flat already.
Rabbit hole here. You should always pull the bolt first and make sure the shoulder has not been compromised by being run loose too long.
Thanks Mark....rabbit holes story of my life!
like this:
@HKforte
I dont have a picture....but when I was doing a trans swap clutch job a few years, I replaced the motor mount bushings on all 4 mounts...that rear drivers side bolt on my east coast truck...that was almost assuredly the original bolt... was corroded down to about 1/3 its dia.
That would be Wall of Shame worthy.
Thanks Mark. I’m definitely a photo guy. Understand now.
Unfortunately, that post was not academic: I pulled THAT bolt out of the truck that was in the initial post. He will need a replacement.
