Float bowl empty, will not prime
TCEd
Traverse City, MI
I reinstalled the carb. I rebuilt recently, stock carb on 81 or 82 engine in my '77 FJ40. Fuel pump delivers fuel to the carb. inlet but no fuel enters the bowl, no fuel at sight window. Engine starts on ether or gas poured in carb. Checked the fuel shut off switch and it has 12VDC with key on and I hear the switch clicking. The fuel flow holes in the switch end are clear and can blow air through them. Are there any other electrical functions required ?
Am I looking at a error in assembly with the float? I set it using the kit supplied gauge and also using pinheads instructions.
ed
I would look at your float needle assembly. It the needle valve is sticking or the float is misadjusted, that could cause your lack of fuel. It may not be related, but what fuel pump are you using on your '77? Did you modify your fuel system to accommodate the relocation of the fuel return from the carb to the fuel pump for a 1981 carb?
What @Stumpalama said, look at the needle valve. Mine was doing some similar shenanigans a while back, sticking open on day, sticking closed the next. It got really frustrating. I finally just installed a new one from a spare rebuild kit I had, I haven't had a problem since.
When I bought my 68 it had a Carter one barrel carburator. The needle would stick close every once in a while. I would just find a rock and smack the top of the carburator. Needles to say this was more than a few years ago. Nothing I would do today but it did work every time.
Apparently the float or needle valve were stuck in the wrong position. I removed the cover and tipped it upside down to see whats wrong and everything looked fine and moved free so I reinstalled it and cranked the engine and the bowl filled and the engine fired and runs. . I previously had turned the completed carb. around in a number of different positions while photographing it and one of those moves may have led to the float hanging in the up position. I've done all the EGR removal and bocking/capping and the smog pump is gone. Now to figure out all these vacuum lines per the desmog procedures. ed
Yes, It has the fuel return line going from the pump back to the tank. ed
