those swaybar extensions are
I take it you made them??
those swaybar extensions areI take it you made them??
Well, I have a reduced arm angle compared to other lifts since I have drop brackets. If you follow his build up thread (which is super long), you can see what he gained when he did it.
Really, there is nothing that says he x-link has to be built like that. There are other places one could mount the front pivot, and other shapes to make the connecting link. Wanna get wacky with it? Use the front mounts on the radius arms in the rear brackets. Now you've just lengthed your wheelbase several inches. Then bend a link to go from the back radius arm mounts to the top of the differential, where you put the x-link style bushing. Now there's nothing out front of the axle.
I don't know what ultimate solution I'll use for the front. Any change is a long way off at this point. But, yesterday, at Disney, I came into a situation that comes up often, that is really unnerving. Coming down a steped ledge, driver's side tire dropped slightly before passenger side, and the whole body of the truck starts to follow the tire. I let loose of the brakes to let her come down a little quicker, and I don't know if it'd really go over, but it's definately unnerving.
yup, it's the fact that your rear suspension moves MUCH easier than the front and it it is leaning with the front. Going up stuff doesn't bother me much in the 80...coming down something, angled was where it felt "goofy" and un-nerving.
In this pic look how far the body is leaning...
Which isn't "that" scary going up...but would be quite a bit un-nerving facing downhill.
Running with the front swaybar disconnected noticeably frees up the front. The ultimate flex is still limited, but the front axle can articulate without upsetting the chassis as much. I've been wheeling with my front disconnected for the last several trips, and I notice a distinct difference in terms of body movement.
But the question would be have you driven to these last several trips or did you trailer it? I drove my XJ's (had a few) all with no sway bars from or rear and didnt have a problem with them. Now with this tank I am not so comfortable to do it with considering the body roll these things have.
No swaybars front or rear. Here's me seeing how unstable she was. The front flex's "ok" with the hitch pin pulled and longer shocks...but there is a much better solution.
Yes very interested, please share,Quote:
Originally Posted by LUVMY804EVR![]()
I've been considering doing this for several years now but never pulled the trigger (radius arm and caster issues holding me back on the front but seems like a great idea for the rear). Have you come across any good candidates for bags?
Yes, Firestone bags. At home I have the specific part #'s I'm looking at if your interested. If you go to Firestone's site you can download their application guide. I just went through looking for those with internal bumpstops that have appropriate travel and aren't too large of a diameter. The application guide also lists who's using the bags, and Kelderman has several listed in the Firestone airbag guide ( http://www.keldermanairride.com/lift-kits/ ). Getting the bags isn't THAT expensive, but when you tack on the cost of a good control system that will let you have pancake, ride height, and topped out all programed, plus 3 wheel, ect. is pricy. Don't really need 3wheel motion like the low riders have, but like in these pictures it would have been nice to dump DS Front Pass Side rear and max out DS rear and DS Front to get the most pressure on the ground as possible, which essentially, is 3 wheel action. It's gonna be a while before I get to it, for sure. Time and money ya' know. Maybe I'll just start with the rears and a compressor with manual operation - I'd like to be able to dump the rear for my dogs to jump in and out.
Part of my shock choice being an adjustable shock is because it's preperation for bags - as bag pressure changes, so does the amount of damping you need to control the truck, so I figure ultimately I'll pick a couple of pressures I like for different stuff, and have a couple of coresponding shock setttings. - but that's down the road a bit.
