I used Crusieroutfitter's tube and needed to grind down the flange.
Im NOT worried about the core or other.
just my .02
just my .02
Doh, I thought it was your flange that wasn't clearing...
Sorry, we probably have a terminology mix-up. I called it a 'flange' for lack of a better word. According to the following write-up, it is called a 'retaining collar':
Anyway, mine won't fit in the 3" tube and I would need to grind it. Question answered, thanks all who chipped in. Kurt, I'll probably be ordering a tube shortly.
by Kurts shop
The following post might make you think twice about that:
https://forum.ih8mud.com/40-55-series-tech/215384-cracked-frame-repair-advice.html
I was looking for such a post in Chicago's build post before. That's the first crack I've seen there. I'm still not convinced I need more reinforcement there, but I'm going to take a 2nd look underneath. It seems like it would make sense to weld the x-member to the frame at that location...
I had the larger six sided nut as in the above pic and "knocked down" the high points/corners with grinder Did not have Kurt's tube but reinforced. I was/am eliminating the spud shaft. Unfortunately now I need a new u-joint as "spud" adapted 11/16" - 3/4" splines. Now I'm thinking of changing column cause..hell it's all apart now, and I have a tilt column laying around.
Bob in CO
