Build FjBroBri's Lx450 Build
In order to use the stock crossmember new mounts have to be installed and nuts welded into the frame. Now the crossmember can be bolted in the same way it was meant to just forward 5.5 inches.
Another thing you run into with these swaps is that the lx fuel filter is located under the intake. So when you change engines to the 2uz you need to come up with a fuel filter solution. The fuel hose on the left is the stock tundra hose from fuel rail to frame rail and the filter is mounted half way down the frame. The middle hose is the 1fz from the filter under the intake to the fuel line near the brake master. Lastly the one on the right is a hose we use on different swaps, it is a off the shelf Toyota hose for 93-95 22r. Lastly the tundra fuel filter.
The bumpers and sliders are now at the powder coater being color matched to a different color and some texture too!
The lift is installed and pics will be posted tomorrow. Mike says "things are coming together." Maybe he'll chime in..........
