- Thread starter
- #61
All the ducks are in a row for tomorrows work.
The two extra Toyota tie rod ends that I ordered (since I mistakenly ordered tie and relay ends) are delayed in the land of brown shorts, so I had 4x4Labs send half a set of their aftermarket ends. This will be great though, since I will have a side by side comparison of how long the OE and aftermarket last.
The pics show the OE end on the top. The Toyota end is painted, but that is about the only plus over the aftermarket. On the other hand the ends from 4x4, have a zerk fitting, simply outstanding for keeping the grease in there fresh. I was also pleasantly surprised with how well they are sealed, they have the same snap ring around the bottom of the boot, but they also have an additional snap ring where the boot meets the taper, very nice. The balls seem to pivot just as smooth between the two. Overall, the aftermarket actually seems to be a bit beefier, even the castle nut and cotter pin are larger than OE, all that combined with the fact that they are cheaper and come with the needed jamb nuts, makes em a no-brainer.
I've also got some of the new birf seals from marlin, new knuckle studs with the torx drive and the knuckle kit ready to go in since I'll be half way there with the arm replacement.
and they don't salt here.
