FJ80 Tcase Help
Eagle County, CO
Hello all, this is my first post. I am by history a rock crawling guy (currently have a 4dr JK on 1 tons, coilovers, 40's etc.) but have wanted for years to do more of an expedition style rig and go on some adventures. Funny enough, after watching the recent xtreme 4x4 Trekking Tacoma episodes I decided to get off my ass and go find a rig to start building up. After looking at alot of different options I decided on doing a landcruiser. Found a really sweet deal on a FJ80 3FE after a few weeks of looking. I am going to pick it up monday. A really stupid good deal. This guys had it sitting in his front lawn for 2 years because a bearing in the Tcase froze up and it hasnt moved since. Ran great before that no issues. Which leads to my question: Looking at local parts searches when pulling up 1991 FJ80 I get two options 11:1 speedo gear ratio and 12:1 speedo gear ratio (31 tire)...which is correct and/or any reason I couldn't do the 12:1? Also, since I'm getting a new one is it worth doing the Slee part time conversion before I stick it in the truck? Thanks and look forward to spending some more time on the forum.
Welcome to mud. if you want a rebuilt transfer case, call Robbie bbie Antonson in Boulder, Colorado. He is probably the most knowledgable guy around on the 80 series transfer case. He did a great job on mine. Stellar reputation.
You kind of have to wonder how that happened. These transfer cases are fairly bulletproof. A seized bearing would be a sign of oil starvation. Makes me wonder what else was neglected.
Used FJ80 transfer cases can be had from between $100-$200.
The speedometer drive gear you're referring to is in the rear output housing of the transfer case. 99% of US spec FJ80 came with 31" tires.
Thanks guys appreciate the info. and Jonheld you make a good point. Everything i've heard about FJ80's (espcially the first couple years) is overbuilt and underpowered. So the tcase going out might be a sign of other things to come. so maybe rather than spending
LOL. That is the truth. The 3FE is a very reliable motor, but it is 1987 technology that was designed to run on 3rd world fuel and last for years without any maintenance and be mostly field repairable. Not a lot of magic on this one.
Essentially it is a tractor motor. Lots of low end torque that fades as the RPMs increase. It will pull a house off its foundation just a bit above idle, but you have to really get into the throttle to merge onto a highway.
It will be a slow ride by today's standards, but it will always get you home.
Welcome to the Mud board. Here's the official salute :flipoff2:
Please fill out your signature and your location under your name.
If you got a new one taken apart, I agree, go with a part time kit along with a 3:1 Marlin crawler gear set. Given the super duper high output of the mighty 3FE, the extra crawl ratio will be a welcome mod.
As far as the speedo gear ratio, I had a '97 80 series with 285 tires and bought the correct gear compensated for the larger tires. I'd guess the same thing can be had for your '91 as well.
Just yesterday I took two 2013 JKUs mild wheeling in the mountains near by. The lady driver was having way too much fun for being her first time, while the husband was a "little" tense sitting in the passenger seat. Given that the odo showed only 1,000 miles, I can see why he was a tad tenuous :D
