I am having problems with a ticking noise coming from my power steering pump. I already replaced the pump and gear for a new one (due to oil leaks). When I turned the vehicle on w/o the PS pump, ticking noise is gone. It sounds like a ticking noise every time I install the new pump/gear. Do you believe it has something to do with trapped air the the PS system (pump cavitation)?? We bleed the system and noise was reduced; however is still there (light ticking noise) I was using power steering oil, and I was told to drain it and to change the oil for ATF. When we changed the pump and gear, we looked inside to look for any chipped teeth at the oil pump-gear without any indication of chipped/marks on this gear. Any help or advise will be greatly appreciated.
