Hello all
I'm having my fj80 3fe clunk when shifting from park to rivers or drive
It's 1992 land cruiser FJ80
I'm attaching video
Please help
I appreciate it I will try it1991 3FE with A440 here. I fixed my loud thud after doing this: Get a grease gun and required grease and grease the front spline and front and rear drive u-joints. There are 3 fittings that you need to grease: 2 at front shaft and 1 rear. If you do it yourself and do not have a rack, then you will probably have to drive the car back and forth to position the fittings so you can get to them from under the truck. There is a good write up on mud (how much grease, type of grease, etc.) if you search grease driveshaft.
forum.ih8mud.com
Here is the video link to YouTube
You can only use Toyota branded motor oil. One guy used 5w-30 mobile 1 and Toyota sent a hit squad to his house and killed his entire family and then his rig caught fire.If it’s the valves and while waiting on the valve job, I quieted my clicking valves on my 1991 3FE by switching to Shell Rotella 15w40 semi synthetic with an OEM Toyota oil filter. Made a huge difference. Of course mentioning oil on mud usually starts another debate but I’m just offering a solution that worked for me.
