Mace said:Yeah, but I hate the 80 series ring and pinion size...
Even in a front axle, being reverse cut (assumption) most of the nasty weight put on the front end is while backing up under power.
dabruin15 said:pigs are the way to go huh. I thought they had the exact same axles as the 60s
Mace said:30 spline longs
Tapage, which ring gears are 9.5"????
Still confused, 40's and 60's have a 8 7/8" and a 80 has a smaller ring gear than that.Tapage said:9.5 ring .. 8 7/8 is standard in 40 and 60 series .. and rear 80 series.
Mace said:Still confused, 40's and 60's have a 8 7/8" and a 80 has a smaller ring gear than that.
Where does the 9.5 come from?
Mace said:Rear 80 is the same as a 40, front 80 is mini stuff.
at least I think the rear 80 is the same size as a mini
Mace said:that is because you are measuring the top of the ring gear.
Mace said:That size will differe dependong on the gear ratio...
