I have a 91 FJ80, and I am looking at a good deal on a 97 cummins ram 2500.
I want to do the swap in a few stages...
Fisrts stage, just get the cruiser running, I am fine with 2wd, for the time being, but it would be nice if there was a cheap way to keep 4wd.
Second step 4wd and axle and suspension upgrades... Possibly portasl, possible 3 link... But that is a while down the road.
Background... Cruiser is my wife and mine's daily driver... Our only daily driver... We need better MPG.
I would like to keep the cruiser automatic... and hupefully one day all wheel drive...
So It seems like the the 47rh is a good transmission to go with.
My immediate problem with the 4wd is the Passanger side drop.
I dont really want to invest in adapters/tcase that go this way as I want to eventually put a Dana 60 up front with will be a drivers side drop.
Questions:
1. Is there a transfer case that can be switched from left side to right side drop and vise versa... This way I would not be afraid to invest in a tcase if I knew I could still use it with a Dana 60 axle.
2. Is the Dana 60 on the Dodge able to be adapted to the Cruiser. I Know it could probably be narrowed, and have radius arm mounts and spring perches put on. But is it economical to do that, or just have one custom built.
3. Is there a way, or is it a good Idea to adapt the 6bt to the A440F?
4. Is there a way to adapt the HF2A to the 47RH?
5. Which tcases have a center diff that would be practical for this application.. Off the top of my head, the only ones I know are LC tcases and the H1 tcase.
6. Am I crazy?
Ryan
Questions:
6. Am I crazy?
Ryan
