Hi all,
I will be replacing my fj62 fuel filter due to stalling issues that may be led by a bad fuel pump, but first I want to replace the fuel filter to cross that off as a culprit. I have other threads about originally thinking it was the battery and replacing all components, also replaced the efi relay and it still will intermittently stall out, and also has trouble on a hot start. The original owner replaced the fuel filter, and i noticed also replaced the gas tank, but not the fuel pump. The fuel filter is easy to access on the fj62 so figured we start there - now my question is do you need to depressurize the system or is this not necessary? I've seen different ways like unscrewing the gas cap or unplugging the open circuit relay while the car is running.
