FJ62 Harness + Halogen Upgrade - 2024 option?
Austin, Texas
Hello,
I have been reading for 4+ hours on the different lighting upgrade options. Based on the heat from the Halogen bulbs and the cost, I would like to go with an upgraded harness and H4 bulbs. Any current recommendations?
For the harness, I see two options:
-wire with relays: SMS upgrade SMS link
-wire without relays (I think): IPF wiring IPF Link
For the housing, Hella seems the choice. Where is the best place to purchase? Here is what I found so far: classic garage link. I’m assuming these allow for only bulb replacement, and its not a sealed housing?
Any recommendations on bulbs?
FYI, I would like to make it so all 4 are on with low beam and high beam, advice recommended!
Is there a koito/OEM upgrade for the 62 (4 rectangle lights)? I've only seen the 7" round kit.
Even stikl, to have all four be on/off you would need to get four h4 rectangle housings. Stock the inner pair are h1 and have high beam only.
I don't think you'll find a wiring harness that gives you control over 4 h4 bulbs so I would expect to build or modify one. I plan to do something similar for a friend's 62 using a modified version of slcfj62's "ultimate harness" design.
