OK. No, I don't think (yet) removing the fixture would reveal a quick fix....Just pulled the light out (Yes, it's a 62). Should I try removing the fixture? It's never worked properly for me anyway...
What we are confronted with is identifying the short to ground behind the Dome fuse on the Dome circuit.
In other words, with the Dome fuse installed, current is passing through the Dome fuse along a path to ground that it shouldn't.
...so, for example, a switch isn't OPENING all the way when it is switched off, allowing a small amount of current (not enough to illuminate a bulb) to continue to flow even though you have set the switch to OFF.
Or, a small break in a wire might be touching ground, allowing some current to 'escape' and go to ground...
All the door switches for the Dome lights work off the same principle. When the switch at the bulb is set to 'Door', then the path to ground is controlled by the door switches.
So when a door opens, the switch CLOSES and completes a path to ground for the current to flow from the + battery post, through the Dome fuse, through the Dome Light switch, through the CLOSED door switch and to ground.
Ground in this case is the metal body or frame...and since the neg battery post is also connected to the frame, then any circuit that 'sees' ground to the body/frame is complete and current can flow.
If a door switch is not OPENING completely when you shut the door (and the Dome Switch is set to 'Door'), then current might be able to 'leak' through that partially OPEN door switch...but in not sufficient enough quantities to illuminate the bulb(s).
A first step might be cleaning the contacts on all 5 of the Door switches.
You could also, possibly, use a multi-meter to measure for current leaking at each switch:
1. battery installed and both battery cables connected to the battery
2. Remove Dome fuse
3. Set Dome switches to 'Door'
4. Pick a door switch
5. Install ammeter (use the fused setting) in-line between ground side of door switch and ground
6. Sit in vehicle with all the doors shut (or just make sure that all the other doors are shut and the switch you are working on it held shut while you take the measurement)
7. Reinstall Dome fuse
8. Check for current reading on ammeter
9. Remove Dome fuse
10. Unistall ammeter, reinstall door switch and move on to the next door switch
If the ammeter reads a current and that current is the same value as the leak when the ammeter was installed in-line off the neg battery post/cable, then the short is between that door switch and the Dome fuse.
You want to avoid allowing the ammeter to see the full current of the closed circuit (when the bulb illuminates), because if the current passing through the circuit is greater than the capacity of the ammeter, it will blow the fuse (on the ammeter). That is why it is better to use the circuit on the ammeter that is fused. Commonly, they are rated for up to 10A. I'm not exactly sure how much current the Dome circuit draws when closed...but take a look at the rating of the Dome fuse...it should be below 30A...and that rating will be greater than the current that is flowing through the closed circuit.
HTH
