'm suspecting the dome light/carb fan circuit since the carb fan (when it's supposed to go on) keeps going on and off for about 15 minutes. Sometimes it doesn't go on at all and yes, the wire and terminal on the sensor are good. Also, the dome light isn't coming on when the door is open, so maybe it's the door switch causing it.
I have outlined the circuit(s) for the Dome Lights, Carb Cooling Fan and Alternator in the wiring diagram (split in two images) below.
Notice that all of these circuits share a common fusible link (labeled #3 in the image) coming off the battery. That fusible link does not pass through the ignition switch, so even with the engine off and the key out of the ignition, all the components on the circuits behind that fusible link 'see' 12V+.
That means, with engine off and key out of ignition, if there is a short in any of those circuits, then it will draw current from the battery.
A short meaning a 'shorter' path to ground than through the designed path of the circuit. In order to current to flow, there must be a continuous 'downhill' path to ground.
The top of the hill in this case is the 12V+ potential at the positive terminal of the battery.
The only time any current should be allowed to flow from this highest 12V+ potential at the positive terminal of the battery is when you do something that closes a switch, and when you close that switch you complete the path to ground.
Notice that ALL paths (circuits) on the wiring diagram end up at ground, but current will only be allowed to flow through that particular circuit when you close the switch that completes the path on that particular circuit.
The short is a failure in the circuit (a broken wire, a malfunctioning component like a switch or a relay) that touches ground (chassis or body) in a place along the path of the circuit that it should not be touching ground.
If there is a short on a circuit behind fusible link #3 (also #1 for that matter - the headlights/running lights), it will drain the battery even with the engine off and key out (for the reason I explained above).
The reason why hooking up an ammeter in-line between the negative battery terminal and negative battery cable works is that it can read that 'leaky' current as it travels back to the negative battery terminal, because all circuits go to ground (body/chassis) and the negative cable is also attached to ground (body/chassis).
Remember, the vehicle stands on rubber tires that are insulators.
So, when the short allows current to flow from the highest 12V+ potential at the positive battery post, out through fusible link #3 (for example), down the particular circuit behind that fusible link, through the main fuse of that circuit and to the body/chassis through the short contact....you can measure that current as it travels back to the neg terminal on the battery because it can't travel literally to the ground (earth) because it can't travel through the tires.
And when you pull the main fuse on the circuit that is shorting, it stops the flow of current along the path of that circuit...and that is why you should see the ammeter value drop.
HTH
Nice.So here's what I found. I have a Blue Sea auxiliary fuse box installed for my CB, Ham Radio and Car stereo. When I hooked up my DVM inline, I had a reading of about 50mA. I removed the the 15amp fuses to the three aforementioned devices and the amp draw dropped to 30mA. Still a "leak" as you call it.
So I pulled some more fuses from the factory underdash fuse panel and when I got to the fuse for the "Horn/hazard lights" it dropped to almost zero mA. So there you have it. I have to troubleshoot that circuit now.
Thanks for posting up that info. When I get some time to troubleshoot some more, I'll report back.
So, when the short allows current to flow from the highest 12V+ potential at the positive battery post, out through fusible link #3 (for example), down the particular circuit behind that fusible link, through the main fuse of that circuit and to the body/chassis through the short contact....you can measure that current as it travels back to the neg terminal on the battery because it can't travel literally to the ground (Mother earth...Pachamama) because it can't travel through the tires.
HTH
Thanks for rephrasing that Jaw...that's what I was trying to communicate but I guess it didn't quite get the point across...Just a clarification: Tires have nothing to do with the circuit. The neg pole of the battery is connected to the frame, so ground is the frame, anything metal connected to the frame, or any wire that goes to the neg terminal. i.e. the return path to the battery. Not literally "the ground". If the tires were metal it would work the same. Glad they are not.
You should see the switches for the front dome light in each of the door jambs. I think there is a thread about cleaning those contacts, but you'll have to do a search to find it.Also, the dome light isn't coming on when the door is open, so maybe it's the door switch causing it.
Any luck on this? Are you still seeing a battery drain?When I get some time to troubleshoot some more, I'll report back.
Have you been able to narrow it down to a specific circuit(s)?...by pulling the fuses at the fuse box with the ammeter installed in line between the neg battery post and neg battery cable?Having the same issues and wondering the same..
Yeah, after you run this test, if you identify the circuit that is causing the drain, then post back up and I'll do my best to help you troubleshoot that circuit further....
No, I don't think the troubleshooting with JLH911 got into working through the Dome circuit itself...which means we didn't find a solution yet or reveal any tips/best practices on how to approach troubleshooting the Dome circuit (once it has been identified as a source of a parastic draw).Did I miss your tips on doing this? Turns out pulling the rear dome light didn't solve my problem. The draw is definitely in the dome light circuit. I've had the fuse pulled for a few months now..![]()
