- Joined
- Feb 26, 2003
- Threads
- 211
- Messages
- 1,859
- Location
- Sherwood Park, Alberta
- Website
- fawcusfitness.com
That is too bad that did not work. Basically just select make, year and model and they will show up.
That's pretty obvious now that I've looked a little closer. I believe those Bilsteins are for the stock height application, OEM replacements not lifted. I believe you can still use those for a small lift but you will lose some suspension travel due to the extended limits of the shocks. I'm no expert, but that is probably frowned upon and might be damaging in extreme conditions. Bilstein does not have a specific set of shocks for lifted FJ62's. You have to buy ones based on collapsed and extended suspension measurements in their custom shock series and either mod the truck (weld and eye connection for the front shocks) or use eye-to-stem adapters.That's pretty obvious now that I've looked a little closer. I believe those Bilsteins are for the stock height application, OEM replacements not lifted. I believe you can still use those for a small lift but you will lose some suspension travel due to the extended limits of the shocks. I'm no expert, but that is probably frowned upon and might be damaging in extreme conditions. Bilstein does not have a specific set of shocks for lifted FJ62's. You have to buy ones based on collapsed and extended suspension measurements in their custom shock series and either mod the truck (weld and eye connection for the front shocks) or use eye-to-stem adapters.
5100 Series Shocks
Ok, I got everything installed. All parts worked great. The stem to eye connector worked perfect and bolted right in. These connectors seem to be built really well. The top of the front shocks still need to use the 5/8 bushings to mount to the connector. All other bushings need to be 3/4". The ride is much better, mostly notice that its a lot less bouncy.
Member ATXFJ posted earlier in this thread the compression and extension measurements for a FJ62 running OME 2.5” springs. They are -
Front: 349mm/589mm (or 13.7"/23.2")
Rear: 357mm/582mm (or 14.1"/22.9")
Whatever you do, take carefull measurements of the distance between the mounting locations with the suspension completely unloaded (as in up in the air) and the current shocks removed. Calculate the minimum distance by subtracting the distance between the axle and bump stop. Then buy your shocks by the dimensions. I cannot begin to elaborate on how many times I have seen parts guys produce the wrong shock based on the manufacturer's literature. Don't rely on it.
x2, solid advice. Shocks that come with lift kits have also been the same for me more than once.
No matter what anybody tells you, you do not want the shocks being the limiting factor in the suspension.
I have ran 5150's with OME springs. Liked it but not a big fan of the 5150's.
Cheers
Why didn't you like the 5150?
