My Toybox was assembled when I got it and I had no reason to take it apart. No help there.
Have you called Marlin's and talked to Dave or Marlin?
Phil
You need the low speed thrust washer. This is a aprox a 1/4" thick and is locked to the 19 spline output shaft with a ball. When you took apart the stock RF1A tcase (mini truck box) the thrust washer was located under the 6308 bearing. We have bins full of these let me know and I can send you out one and the lock ball. Also if you split case has provisions for the dowel pins then you do not need the aluminum locateing ring.
