FJ60 to FJ80 rear end?
Yucaipa
Hello,
What is the best rear axle / rear end set up for a FJ60? I just ordered an ARB locker and 4.56 gears for my rear end and dropped my third member off at the shop to have it installed ($450 labor). Well I tried to order some chromoly axles and found out PP stopped making them. I'm worried about running factory axles because I'm running a built LS 6.0 engine. What should I do?
Will my rear third member fit the front since it is still stock?
You can swap 3rds no problem . Your rear should be plenty strong if you treat it right.
