I thought stock but am trying to see if work was done to it. Are they changeable? This cruiser was bought new in 84 and my parents finally gave it to me in 2015. They used a local mechanic for repairs. Not too sure about him though. Limits are HC 4 and CO 40. Last run HC@6.5 and CO@200.
Yea, they come out pretty easily without removing the carb. You have to pull the primary jet and see what is stamped on it.
I'm not an expert on the diffferent carb bodies, but according to SOR, you may have a 1.47 primary jet. It would be interesting to drop it down a bit and retest to see what happens. 1.40? 1.38? Ask @FJ40Jim or @pinhead. There are lots of sizes available. You can get Mikuni jets from a motorcycle shop too, supposedly. The one I finally got to pass I drilled out myself wiwth a hand drill. 1.24 is the stock jet for CA. I run a 1.29 now. It's noticeably lean when driving. I could bump it up a bit and just put in the smaller one when I go in for the test. 1.36 is the Federal spec.
Page 042 Land Cruiser Carburetors, Parts, Kits & Gaskets <- Click the "jets" tab.
Running some E85 will also lower your HC a bit. Don't leave it in your tank for long. Put in a couple gallons for the test and then fill up with gasoline right after the test.
