- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,564
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
A more secure connection where they still have a single tiny green O-ring..
Ya, since the mineral oil needs to be flushed out and PAG oil used, it’s best to just get PAG oil with dye already in it. That’s what I did.One thing that I do when I charge a system is to add dye. This makes finding a leak in the future much easier.
I was born without inherent knowledge of this and many other automotive things but I'm subbornly tyring to learn on my 87 FJ60... is there a link you can share on a kit that works. Preferably with one with directions, pictures a bonus. The videos I find are for much newer or different vehicles so for me its like they are in greek and I'm trying to translate.There is a charge amount difference between 12 and 134. IIRC, They hold roughly 1.7lbs of R12, the conversion for R134 is supposed to be about 75% of that. When I did mine last week, it was happiest with only 1lb of R134, so keep that in mind as well. Just don’t put the same amount of 134 in as 12 came out.
You can get the conversion at any parts store. It’s essentially just fittings that go on the compressor. It’s like $30. You can also get PAG oil with dye there as well.I was born without inherent knowledge of this and many other automotive things but I'm subbornly tyring to learn on my 87 FJ60... is there a link you can share on a kit that works. Preferably with one with directions, pictures a bonus. The videos I find are for much newer or different vehicles so for me its like they are in greek and I'm trying to translate.
You're awesome! Finally something from the factory. Interesting that you don't have to replace the shaft seal on the compressor or the orings around the input shaft which I did to a spare I had laying about... Dang!Who ever adds things to the 60 series FAQ should add this document. I am in the process of doing this and found the Toyota TSB for converting. I figure if anyone knows how to do it right Toyota should.
You have any pics? Just curious what is it.Slight tangent but worth adding... The really nifty AC fittings are the the new pad/block style that use Parker's washer-type "stat-o-seal". Why they aren't mainstream automotive yet is absurd. No tooling changes, they're stout as hell, and make health checks during assembly an absolute breeze.
