FJ60 PS Pump & pre 79 2F
Afton VA
Has anyone drilled & tapped their pre 79 block for a FJ60/FJ40 power steering pump? I have a 78 2F and a pump/bracket from a FJ60. I’m wondering if this is the best way to go or if I should try and fabricate a new bracket.
Pablo,
I've made the mounts out of cardboard and am getting ready to start making some chips and sparks. I just finished overhauling the pump two days ago. I wanted to make sure that it was in good shape before proceeding. One interesting think to note is that there are no longer any of the 24 "slipper" springs available from Toyota. I bought the last one :)
One last thing about drilling and tapping the block. I wouldn't try it. You could potentially ruin the block when the whole thing could have been taken care of with some mounts.
How so? People drill and tap cast iron all the time. You will be drilling into the water jacket, but the head bolts also enter the water jacket. You just use thread sealer.
Pin_Head,
Unless I had a quite steady hand, sharp drill, a good drill motor and some way to make the holes square to the block I'd try another method. Plus, the holes would just be another three places that water could potentially leak from. Just my .02.
Doug_S said:
Pin_Head,
I am a firm believer of jigs & templates so I would have something rigged up to ensure alignment and hole depth. But still, drilling into the block leaves a chance for disaster.
I was hoping to find someone who has successfully done this to get some encouragement.
I am always willing to consider alternatives. I keep reading about PS brackets by Bill Dorry, Does anyone know if these are still available and if he makes one for the FJ60 pumps?
When, not if, I get my new shop together (I had to move due to a divorce), I'm going to be making a few FJ60 pump brackets for the non-drilled 2Fs. I intend to make them out of 3/8" steel although the aluminum idea is kind of attractive to me; trouble is, I'd have to anodize them otherwise they'd look like S**t very soon.
Pablo C. has already indicated that he needs one so I'll make one for him in addition for one for me.
Steel first though. These will closely match the set put out by CCOT some time ago. All I have are photos to look at, I have not handled theirs directly. The CCOT set is no longer available. I think, however, their set was turn key, in that it came with pump and steering box as well.
Cheers!
JCJ,
Dorry mounts are for saginaw pumps, AND, they use smog pump location.
The mounts Doug and I are talking about are for putting the PS pump found on a 60 on your 2F block, in conjunction w/ your air pump.
Mark W has indeed drilled the blocks, but felt it is not worth it. He posted on one of the posts I responded to.
Cheers!
Steel or Al, does not matter to me.
Any ideas on when you will be getting down on this? Remember, DocB has the CCOT kit on his rig, so we may be able to get measurements from him...
How did the PS pump rebuild go? Were the o-rings all fuqued up?
Actually the o-rings looked fine. The springs were/are a big worn but came through in the tolerance specified by Toyota. It's a lot cleaner. Pablo, have you heard anything about shortening the steering column as the result of putting the fj40 steering box in?
You mean the 60 box?
If so, I plan on a 55 column from steer wheel to firewall, then a mix of 40 shaft mated to 60 intermediate shaft...
PabloCruise said:
JCJ,
I thought I read something about not being able to use headers with the stock PS pump. Does this sound right or is it just my imagination?
JCJ,
Not sure, but I think headers are o-k with PS pump in stock location...
I think all the Cruiser retailers sell the same header for '79 and up where PS could be an option.
http://www.sor.com/sor/cat324.tam?xax=7165&page.ctx=cat324.tam
SOR says they will not work with a PTO winch. But they are ISO 9001 compliant! Yippee!
Well, I have a set of aftermarket headers on mine from the previous owner. It looks like they'll work I just have to make sure not to get the pump too close to the #1 header or I could have problems.
