rehashed over and over, but....
1981/2 FJ60's are odd balls with poor parts support (ala it's own steering box).
1981-1983 and even to 1985 headliners suck (esp the early). The "foam" style are really better.
H55 swaps can be done to any, but t-case will not work from 8/80 to 1983 (7th month, maybe earlier). I had one in my May 1983 (used H55/t-case combo) easy fit.
4/5 1985s and later directly take a H55- but I did not say you can't go earlier (see above). Driveshafts (retube about $100-$200 depending on location), gear shift lever (t-case) and a 5 minute grind on bellhousing that's it.
11/1985+ get 38mm t-cases- the best case Toyota made IMNSHO.
4/5 1985 + will even accept FZJ80 steering boxes as replacement.
FJ62's- I don't have a fondness for them, especially the common 10mpg feature (most get that, don't argue the truth!). E windows and auto are downside. Steering wheel/dash is much better than FJ60, rear sway bar, and rear shoulder seat belts are common.
I'd like FJ62's if they were EFI 2F's (3F head on 2F) or carb 3F's (non US) and a H55.
I have a 83 fj60 dont remember what month.
Why would a T-case from 8/80 to 83 work with a H55F? The 38mm idler shaft?
If I recall the differences in early steering boxes VS later boxes is just the bolt pattern? Are there 3 different boxes for the 60 series?
When I bought my 60 it was bone stock, it was mention on here that in 83 they came with York compressors but mine has a Denso compressor in a factory bracket. Was this a crossover year for this?
What about a fj62 frame makes it stronger? Double layering in the moast rear cross member?
I plan on starting in the next year doing a frame off resto on my 60 dooing a 2FE with H55F. I would love to have the best aspects from all years.
Noooooo.......If I have a pet peeve on ih8mud it is the "3.73". That, is a Dana ratio. These are Land Cruisers. The FJ60s ring gear has 37 teeth. The pinion has 10 teeth. So the gearing is 3.70. Spike knows that.
