FJ60 fuel pick up: which line is which?
Metro NY
2003798
In the pic above the left/top vs the right/bottom... Which is pick up and which is return?
Cant tell by the picture but whatever tube is the lowest will be the pickup. If they're exactly the same depth then it doesn't matter.
I need to know which of the two metal tubes on the pickup is which.... I need to hook up the lines to/from the pump...
The stock hard lines along the frame are gone, I'm hooking up a Holly Sniper FI
Googled and searched... can't find this info... anyone?
FJ60 unit on the left, BJ60 returnless unit on the right. This should answer it.
at least that's the way I interpret it based on the diesel sender that has no return.
Any independent verification of this?
