It is spring under but I have a 3 inch lift I am going to install. I have seen some people using the trailblazer ss intake and the H3 pan. My main concern is the exhaust. I plan to run the 4l60e so my wife can drive it also. I was really hoping someone had found an exhaust manifold that would fit. Thank you for the info.You don't say what the rest of your pig setup is.
You can do a truck pan depending upon your lift. I was spring over and it fit fine. I have since gone with an H3 pan on my runner. Right off the bat on FJ55 #2, I went with the H3 pan. Even at $250, it is a good deal considering it is new:
Amazon product ASIN B00BZR4ZW6There is also a company Central Performance Wiring that carries it also. Not sure on their price but it was in line with Amazon.
No way I would buy a used Camaro pan for nearly the same price.
I can't comment on headers... I had a set of Hookers and they warped to hell. I have since gone to C6 center dump manifolds slightly modified on my daily. On my FJ55 #2, I went with a truck manifold on driver and a turbo truck manifold on the passenger. Both needed some modification.![]()
Do you know what block hugger headers fit without modification?2002 Camero 5.7 oil pan
Shorty block hugger header
Did the headers fit or did you have to modify? I followed your build and if I remember correctly you were having trouble with fitment.I used Sanderson block huggers and I believe a Camaro pan, also. You'll want a pan with a shallow sump to avoid hitting the front axle.
LS oil pans with dimensions (all of them)
Burke posted this as a link to another forum:yes: I thought I'd make a thread here on SNS:yes: LS engine oil pans - all of them Hummer H3 5.3: 19212593 Capacity: 5.5 qts Oil pan: 12614821 Oil pump pickup: 12608593 Windage tray: 12611129 (same as c/k truck) Dipstick tube: 12584738 Dipstick...www.stevesnovasite.com
Thank you.No reason to go with trailblazer ss intake over stock truck intake. Minimal gain and same height. I forget if the TB required new injectors, fuel rail, etc.
Sprung under I would go with a new H3 pan without a doubt. No way I'd pay $100 or more on a used Camaro.
As far as I know all center dump headers will fit without mods. My experience with Hooker says that brand is junk. I had a fab guy that modified my manifolds for me. No big deal. I doubt you will find a stock exhaust manifold set that will work without mods. The FJ55 frame is fairly narrow; 24"(from memory) while full sized cars/trucks are closer to 30".
