FJ55 350 Chevy Conversions....Help!
Hello Pigs. I recently purchased my 1st (FJ55, 1973) and the orignal engine and tranny are shot. So...I am planning to swap them out for a 350 chev and turbo 400. Can any of you long time pigs direct me to a thread that can give me some pointers on the swap?
Thanks in advance,
EyeDuhHo
eperry: I am also in Boise. I'm afraid that I can't find any definitive information regarding a 350 swap. There is a lot of vague info out there.... have you found anything on the net?
Thanks Lil' John. I suppose I should be more direct in my request for information. Since I have done swaps before I am somewhat aware of the process. Really, what I am looking for is workable "combination" recipes from Pig owners that have gone through the process. Example: 350 with a TH350 and NP203. The specifics of how, I believe I can figure out as I go.
Thanks again,
Eye Duh Ho!
With a pig that you are gonna wheel I have to say the NP203 doubler is a great option. It's too long for a 40, but in my 55 it makes the drive shafts the same length.
The 203 mates up to a TH400, TH350 or in rare cases you can find them with a manual. I would never wheel a manual again, but lots of people like it.
About 500 gets you the trans to transfer adapter. The 203 to 19 spline split case is the best option, but the hardest to get. Advance adapter makes them for the 10 spline and 16 spline cases.
You get an easy adapter, 2:1 and 4:1 options, and a good length drive train.
Therer's not much out there with much detail that's very specifc to 55s. There is a member on this board that used a Marks adapter (Australian product) for his conversion, he goes by Mtrdud, you can search his posts to see what he did. The Marks adapter is expensive...~$1100, but it allows you to keep the toyoya tnans and transfer case in the stiock position, while still giving you firewall clearance with the V8. So not a bad way to go if you are set on keeping your Toy 4spd tranny.
As others have mentioned, there's alot of options, just really depends on what you want to do with it, and what you can afford these days. After some deliberation, I've decided to go the used 5.3 vortec route and use the GM auto trans with it. For what I want, a durable family truckster to load up and take fishing, camping, hunting, rafting, etc., I like the mileage I can get from this fuel-injected setup, and while I may not be set up for any heavy wheeling, it will be plenty capable to get me where I need to go.
I've checked at Barger Mattsen here in town, and you can pick up an "A" grade 2000 and later 5.3 vortec (mileage under 60k, or less thah 10k per year), with the transmission, harness, ecm, all engine accessories for ~2500. My plan is to find one of those I like, freshen it up as necessary, and get started. AA and Downey both make adapters to mate the GM 4l60e to the toyota transfer case, and then there's other details to work out of course...Front driveshaft clearing the transmission oil pan (There's a modified output shaft and flange for this, see BTB products), rear crossmember for the transfer case (AA makes one specifically for the 55, works like the standard 40 rear crossmembers, bolts on to the transfer case).
In a perfect world, I would put a 5speed NV4500 manual in...But they are considerable more expensive than the 4l60e, so I decided to just keep the auto most of the vortecs come with.
My $.02...Good luck! I hope to see you on the road here in Boise.
eperry, $2500 for complete 5.3 and tranny is VERY high priced. I could have got 6.0l for about $2200 with 30k miles on it... in CA(my 6.0l without tranny was around $1500ish):eek: The place was offering 5.3l's for around $1500 complete with tranny and 30kish miles:eek:
Definately shop around and remember that shipping an engine is "only" $300-$400:cheers:
On BTB parts, I'd recommend looking somewhere else. The output you speak of is probably an Advanced Adapters unit that has been marked up:rolleyes:
Thanks for the tips Lil John. I will do some shopping/haggling when it comes time to buy...I also scour craigslist regularly, and have seen some better deals there too.
And agreed on BTB...Downey has the same outpout flange/shaft for ~ $100 less. Thanks again.
Thank ya'll for the great advice! I finally decided on a "doner" rig. It's 91 chevy 3/4 ton with the 5.7 TBI and 700R4. I like the idea of having the lower 1st gear and the OD as I will use the FJ as a daily driver. I'm not a hard core 4-wheeler but I do like to fish and hunt. So, when it comes time to get past the tough spots I don't want to be stranded. My nephew and I start dismantling the truck this Wednesday. I'll keep you up to date....
Let me know if you need specs. That's the same combo I'm running.
B&M ratchet.
OK....the engine should be completely out of the pig tomorrow. Thanks Perry. I couldn't see any automatic shifters.
Take a closer look, the first six shifters are automatic, they just look like manual shifters.
Lou
Ah! Yes....now that I have opened my eyes, I can see them!!!
Thanks.
Update: The drive train is out of the pig. I'm selling the engine, transmission and transfer case if anyone knows of a buyer.
On my way now....
OK...i'm ready to put the engine in...well almost ready. Does anyone know for sure if the steering box will need to be moved in order to make room for the 350?
I am not sure what steering box you are going to put in or if you are going to keep it stock? , but, I have a 60 series box mounted on the outside of the frame.
