Fj45 fuel filter questions
Adelaide
Looking to replace the fuel filter on my fj45. For some reason i have three. Do i need three? One in the cabin and 2 in the engine bay.
I think i can remove one of the engine bay ones but im unsure
I see okay. Thanks for the info. Yeah i thought that too most likely the tank has rust like the rest of the car. Id need to check that out when i give it its first service
If it turns out to have rust. Any ideas on how to clean it out? Or is it best to just replace it
Tanks for FJ45s are not the same as 40s. The filler necks are positioned differently, and the standing seam may cause issues with the back of the cab.
I Have a FJ45 Factory OEM Location Fuel Filter Mounting Bracket Kit Available
- bracket fully restored ,
- includes a OEM Period correct Yellow ZINC mounting Bolt
- also , the Super High capacity & Largest Filter Element TOYOTA ever made
fuel filter , its transparent so u can see if that tank is Really Dirty or Not ?
Eliminating random Speculation and Doubt and replacing it with :
OEM TOYOTA FSM based Facts ......
this FJ45 Bracket Mounts atop your frame rail , just below the Battery to the inner firewall side a bit near your where your metal factory fuel lines pop up from under chassis to up inside engine bay ..............
shoot me a PM for more information , if you have any questions or are interested
in a proper Period Correct 1 time worry free Needed parts Solution .....
Thanks everyone for the info. Probably not worth worrying about period correct parts. The vehicle has had a gas system put on it at sone point so everything is different anyway.
Good to know the differences in tanks as well
Tancruiser - how did you notice your rusty tank? Did you start having fuel issues? Or was the outside of the tank rusty?
Mine had rust and I did the por15 kit and had no further issues. It’s a long process but worked for me.
