Fj45 351 v8 ignition problem
Central coast nsw Australia
hey guys I’m currently 3/4 of the way thru converting my fj45 with a 351 Cleveland v8 and am having trouble with the ignition I have replaced the dizzy cap and rotor button ( electric dizzy ) spark plugs and coil etc, I have spark at the coil but when put into the dizzy have no spark at all, just wondering if I’ve missed something in the wiring or something like that, any help would be greatly appreciated
is the distributor rotating?
is there a fuse somewhere for the distributor?
Post up what kind of dizzy you have.
When you say you have spark at the coil, what do you mean? Power to the coil or spark from the coil wire to a ground. If you take the coil wire out of the dizzy cap and hold it close to a ground (engine block) and try to start it do you get a good spark? If yes, then do the same with a plug wire. If it has no spark then it is in the dizzy cap, rotor, etc.
If you remove the new cap, there is a spring loaded contact in the center that rides against the top of the rotor. Make sure it is there and not stuck in. I have seen that one before.
Pictures help a lot.
What type of conversion kit are you using for your Clevland? Also interested in your transmission type as well.
Also, best of luck on your engine issues.
Yeah mate have power at the coil and have good spark coming out of the coil( I put a spark plug in the dizzy end of the coil lead) checked the contact spring inside the cap and doesn’t seem to be stuck, when I plug in the coil to the dizzy and try the same thing with number 1 plug lead I get nothing at all
Not sure on the brand of the dizzy
I ran into the same issue once with my 351c when replacing the points in a Mallory duel point dizzy, found one of the wires/connections for the points was barley touching the inside wall of the dizzy. Bent it back a little and she fired right up.......I know this is for points but maybe something is touching something it shouldn't, good luck!
Is the dizzy spinning? Power to dizzy?
Sorry for the late reply been away with work, have power at the coil the dizzy is a motor craft I think and the rotor button is spinning when I hit the key
Was the distributor ever pulled out or rotated any? If it was pulled it might be in 180 degrees off. If it got turned or bumped the timing could be out enough to not fire also.
