Long time listener, first time caller here. Honestly, I’ve held off and lurked for fear of spending even more time on here as a registered user.
I’m one of the few who thought it a great idea to import a 43 from Colombia, and it went surprisingly ok despite needing numerous things upon arrival. With that said I did it again, and wasn’t so lucky the second time around.
Neither trucks have a heater in the cab, and in SA they don’t use engine coolant. The 79 (2F 4 speed) was driven all summer long here in Texas running on just mud, rust, and whatever the hell else was in there. Not once did I have an issue with it running hot or overheating, and probably put about 500 miles on it like this. Then I decided to flush the radiator. Followed steps I found in this forum and flushed the system until all water was running clear. Filled it up with coolant and it overheats within about 15 minutes. I’m now regretting even touching it, but hoping it’s better in the long run for what I intend to do with the truck.
The 1970 (2F 3 speed) on the other hand was flushed by a LC shop locally. I had about a 40 minute drive home on the highway, and immediately upon the engine being turned off it poured some excess coolant out pretty decently. The radiator cap was old and didn’t fit properly, so I bought a new one and have not had that issue since. However currently within about ten minutes of being on the road, it sends the bar all the way to the right of the temp gauge. The engine doesn’t sound any different, is full of coolant, and doesn’t seem to perform worse or strain when driving. Thinking it could be the thermostat on both trucks, but also have read that some 40s had the temp gauge reading backwards where indicating hot is actually cool.
Could the lack of a heater be a problem with keeping the engine running hot? Was it a mistake to put coolant in the vehicles when they haven’t used them before?
