Slave and rod are;The spring seats the piston in the bottom of bore to insure a full stroke of the slave. It sounds like your rod isnt long enuff.
Per the FSM. set the pedal height, pedal free play, and then adjust the rod.
I wonder if the return spring is to strong and is pushing the fluid back up to the masterYour spring is way heavier duty than the one on my rig. Maybe your new master is leaking internally - new parts aren't always good. If the slave was bad it would leak externally. Mine spring 72 looks like 018-12A.
I wonder if
Is it supposed to be a one way valve systems?
That I’m not 100% sure on but I did do the swap that cruiser Matt suggested originally.I see this is a FJ43, so it's not US spec. Foreign rebuilders do weird stuff. Did you correct the slaves mounting position as @cruisermatt mentioned? Are you sure all the clutch components are correct for your model or setup? Something as simple as having a wrong part like using the wrong pivot ball, fork, pp and such, can effect the throw of the fork and make the rod not long enuff.
Here's mine off a '74 FJ55, just might be original...What im thinking now is that the return spring is either to short or strong.
That’s wild on how depressed yours is in comparison.Here's mine off a '74 FJ55, just might be original...
018-05DThe spring seats the piston in the bottom of bore to insure a full stroke of the slave. It sounds like your rod isnt long enuff.
I think this is where I’m at, and I’ve got all new stuff ordered and delivered for a local shop to go through and make it all more better.I see this is a FJ43, so it's not US spec. Foreign rebuilders do weird stuff. Did you correct the slaves mounting position as @cruisermatt mentioned? Are you sure all the clutch components are correct for your model or setup? Something as simple as having a wrong part like using the wrong pivot ball, fork, pp and such, can effect the throw of the fork and make the rod not long enuff.
I wonder if you have the right pushrod...I wonder if there is something more going on with the internals on mine, clutch fork / pressure plate, clutch.
For your suggestion flipping should it have been the single arrow or the double arrow.
I'm wondering if you have the "3-speed" slave pushrod. It has a closed acorn nut at the fork end. It's supposed to go with the pressed steel clutch fork.I wonder if you have the right pushrod...
