Yes probably, look at how it’s fit to winch , actually I feel a lot of stress on my brain , who the mather***** think to produce bumper like this ? It’s not even at cataloguesLooks like someone cut out the middle to fit around the winch?
You are using the oem bumper w/winch
good idea to lower it down the frame railI have never seen that before, however maybe some did it to fit differently?
Typically they are on top of the frame rails above the bumper.
Was this lowered somehow to the bottom of the frame rails?
The OEM PTO winch bolts to the top of the bumper on the 40 series. If it didn't it wouldn't align up with the hole in the front frame member for the driveshaft. Possible from a different model like a 70 series.
the obvious thing it’s aftermarket product where there is no sign of Toyota factory touches , I searched many times flat FJ40 , 55 catalogues but ends up with nothing .I already saw a few 40 series where people had "doubled" the OEM bumper, making fatter without going to a brush bar.
Could be a version of that adapted for a PTO winch?
What do you use that line for?
Same setup for my PTO winch and bumper. The hard part is finding the shims for mounting. I made a set for mine.
