My guess is that the engine and box has come out of a Dyna or Coaster bus, which would have the gear stick on a linkage that would mirror image the shift pattern at the stick.
I have one of those too Brian. My first thot was the same as yours. Sine80 and greenfox both had their hands on that 'other' one. Yes it is definitely a reverse shift pattern and yes it is definitely Toyota. 4.99 1st gear with a 10 spline [3 speed t-case] output shaft.
I figure I will set mine up with a Fairey overdrive one day [or year!]
I was the owner of the transmission BB (Brian) was talking about. It is a toyota transmission and it was put in my 55 by someone else. It was installed behind a 2F and fit perfectly with the stock driveline and transfer case (though the transmission hump hole was modified about an inch rearward). The first gear was too low for on-road use and it topped out about 50 mph at 3000 rpm.
Here is the only pic I could find. Nobody could ever figure out where it came from, though I did get a lot of comments about my ability to install it correctly in the vehicleSpecter and MAF guys said they had never seen one. I have no idea where it originally came from.
I always thought that this "reverse" shift pattern would make sense on a RHD vehicle, and was surprised when I drove a BJ74 and it had the same shift pattern as a LHD vehicle. If your vehicle is RHD I would keep it with this "reverse" pattern. That's just me though.![]()
Then you would have to reverse the pedals as well to make is all right!
Pete
I've heard it's hard enough to keep the turn signal and wiper switches straight, so it'd probably be best not to introduce additional confusion Did you ever get your transmission sorted out? I just got one of those, it came with the 2b motor I bought and its disconcerting to use...
If you know how to change over the pattern to norm, please advise...thanks
Yes Mark, I passed the trans on to Sine80 after I got it from shermantank55 (thanks Greg!), as he needed the gearing. Sine and Greenfox installed it in his 40, which is now sold. I did not know you had one as well. What will you install that setup in?
Greg, don't remember if you told me, was your 55 a local (Bay Area) purchase? No PO info on the trans?
JohnnyC - I did not note any numbers; I only had it in my possession for a few days.
Brian
CID 96 does the tranny have any casting numbers? or stamping numbers on it?
does it have a side cover on the opposite side from the picture above?
