FJ40 sniper install/startup question
Santa Rosa Beach, FL
I'm rebuilding a 77 FJ40 and I'm waiting on paint and body. I would like to get the engine started and dial in the timing, etc and see how the sniper works. but i don't know if I need any components from the factory harness to do this. I was thinking if i ran power to the sniper ECU and HEI distributor i could run it without the wiring harness. Has anyone done this? Would really help me to use this down time to dial it in. But if its not advisable, I can wait. Will be installing vintage air too. Obviously would have to hook up power to fuel pump and set up fuel tank and lines. but might be worth it.
thanks. will check out his site. its not a new engine. its just really clean. compression was great so i pretty much left the engine alone and replaced all of the usual seals and gaskets.
Which harness do you mean? The vehicle harness or the Sniper harness?
Project Wrong Way can help us all on this!
Here’s how I wired mine using a relay recommended by Performance Distributors for my DUI. The relay just transfers 12V through a 12awg wire direct from battery to the DUI and doesn’t pass through the ignition switch.
There's really nothing in the vehicle harness that you need.
Aircooled1: as per your request, here’s how I wired the relay for DUI with the Sniper.
I used "This Relay” and “This Fuse Holder”. I used the extra #87 pin on the relay for an LED pilot light mounted under the hood just for kicks. If I need to troubleshoot, I know at a glance if I have power to the DUI. (inspired by all the Pertronix problems in the past). I used 10ga wire from battery to #30 and from #87 to DUI.
Thanks a lot! This is perfect .
Dang!, I just remembered and it's not a big deal but,,,, I got the parts awhile ago to make a modification but haven’t got around to it yet. I wanted to use a relay setup with a wired in base where I could just un-plug a relay from a socket and plug in a new one. I thought it would be easier than un-mounting the relay, unplugging each wire, re-attaching wires and then re-mounting.
Also, the relay built into the Sniper harness has “Made in China” written on it . If I swap them both out, I could carry one spare relay and make a quick swap if I have a bad relay or even if I suspect a bad one.
The bases come without the terminals and need to be ordered separately. Unfortunately, they’re out of stock right now. Here’s the parts I ordered for the change out that I’ll get to doing one of these days.
“Hella Relay Base” - “Bosch Relay” - “Uxcell Terminals”
CORRECTION: For above post #11
I was about to make a mistake. I just noticed that the pump relay built into the Sniper harness is of the resistor type. The resistor is to suppress any induced voltage from the magnetic coil within the relay, when the relay is activated. The induced voltage could possibly damage sensitive electronics.
The non-resistor Bosch relay has been switching on my DUI for 4-1/2 years and the Sniper’s been running 2-1/2 years. I’ll have to look into a resistor type relay if I’m going to replace the Sniper’s pump relay built into the harness. And probably the resistor type relay will work fine for the DUI so they’ll be the same relay.
Sorry if I misled anyone.
Bosch relay on left and Sniper's harnes mounted relay on right.
One recommendation from my own experience. Unless you need other features from the 10 PIN harness, don't use it to power the tach output. Lot of extra wiring for a tach, just hook the tach direct to the distributor.
That would be nice. Which dizzy do you run?
I ran mine in the frame without the factory harness, and it was a fresh rebuild. I'm sure Holley says that just to avoid any liability...it fired right up on first bump of the key, likely better than the carb' that came off.
They're pretty simple systems...was just a 12V feed to the battery, one for the "ignition" and one to bump the starter, basically. (I had a few extras for the CDI/Hyperspark as well, but all the same). Oddly enough, I think that's the next footage in my video-editing pile too. 🙃
