FJ40 Power Steering
Peoria, Arizona
I sure this has probably been asked a million times but heres my story. I have a 1-75 FJ40 with manual steering (the steering gear is sloppy). I want to add power steering, but I want to be as close to stock looking as possible. I searched through the tech links but had no luck finding help for installing power steering except for the Saginaw conversion.
Will a power steering gear from a later model FJ40 or FJ60/62 bolt onto my crusier? And will the toyota power steering pump from one of these later models just bolt on as well?
Any help would be greatly appreciated.
Thank you
If your looking for "stock" then swap a power version of the stock "box". That being said anything will bolt up with enough work. Search the forum, there are lots of references to saginaw, FJ-60/Scout, mini-truck. Good luck
Hi All:
The stock FJ40 P/S set-up is what you are looking for. Unfortunately, those are fairly rare to find - the "mini-truck" type P/S swap is very close, and should work well for you without being too much trouble to install.
Check the archeives at www.birfield.com and I believe that the shop called "J.T. Outfitters" sells a swap kit.
Good luck with the swap!
Regards,
Alan
Seattle
Get a 79 or later P/S box and pump. Make sure you get a pump bracket. It's a staight bolt on. On my 74 I did have to shorten my steering wheel shaft about an inch. Hooks right up to the stock steering linkage.
Kevin
I've done the minitruck powersteering conversion on my 79 FJ40, very simple operation. Wdorry on this site makes the necessary brackets, they're beefier than the JT brackets, good guy to deal with as well.
a 75 block will not have the holes for the pump to mount, those started in 79.
prolly the best(for your year) and its close to stock is the mini truck set up and matching brackets. a mini truck box is the same as stock fj40 except for the housing.........besides that the guts are the same, so it will feel stock and look close to stock
Kevin
Agree with pimp. I have the mini but my block was pre tapped for the PS pump mount (FJ40/FJ60 pump). You will need to use a Saginaw pump, Bill Dorry's engine block pump bracket, a mini 4x4 PS box, a mini box frame mount and the related lines. I cannot speak for the Saginaw/Mini combo but my stock FJ40 pump to mini box is just enough PS for my 32" TSL mudder set up. In other words, it is no where near a new car kind of feel and as a matter of fact it was way less than I expected i.e. it really only comes into play when you are at a dead still trying to maneuver an obstacle. Apart from that, I really do not feel that much of a difference from it and the stock manual box when traveling at speeds.
what could i do on my 135f motor as there i sno way to move the alt over to the pass side of the truck. The head is not taped for it. I am looking for options on this i like the bracket that Mark (marksoffroad) makes but that need me to use a 2f alt bracket that wont fit. Any of you pre 67' guy out there got PS or do i just have to live with armstrong steering.
sorry to hi-jack
McGruff - These are the same questions I came on asking!
I suggest you search by user name (enter me; PabloCruise), and search the 40 and 60 forums, you will find a bunch of things on PS conversions.
If you search for PS threads with LandPimp's user name, that will show you pics of the mini-truck box swap...
My current plan is to mount a 60 box, and use a 60 PS pump on a '78 block.
It is a toss up btwn Doug_S and I as to who will make a mount for pre-PS pump 2F blocks. Search for his posts as well.
I don't want to use a Sag pump, and have heard unflattering things about JTO...
Thanks everyone for all the good info. I think I will try and find the info on the 60 gear & pump swap. If all goes successful, I will post photos of the job.
Thanks again,
Vern
sorry to hi-jack
Landpimp's right, theres no P/S mount holes in the pre 79 blocks. You can use a saginaw pump with a Toyota box. There are brakets for the saginaw that will mount to that block.
I used my alternator bracket on my 74 and made a mount for the Toyota pump to fit it. Moved my alternator to the passenger side with a 78 mount. Pump fits under the stock air cleaner.
Works great...Still need a cooler for it.
I remember seeing a generator on an old 50s chevy that had a P/S pump mounted off the back of the generator... That's what we need.
Kevin
I use a '79 -'85 4x4 mini truck gear, pump, and remote reservoir on my '77 FJ40. My pump is mounted where the smog pump goes with a fabbed bracket.
There are lots of vendors making mini truck gear-to-frame pedistals/brackets that mount the mini truck gear where your old manual gear and pedistal currently reside. Have fun removing the old pedistal-to-frame rivets!
At GSMTR I saw a new bracket by Iron Pig Offroad that mounts a mini truck pump on the OEM smog pump bracket. See website... Not affiliated
Also, if your steering shaft does not have a rag joint, you may need one. See websites like JTO for details. Not affiliated
I recommend calling or going to your local salvage yards and looking for '79 - '85 solid front axle 4x4 mini trucks that have the following parts:
PS Gear Box (bracket not needed)
PS Pump with Pulley (bracket and tensioner may come in handy depending on how/where you mount the pump) Do your research for your model year.
Remote Reservoir
High Pressure Hose (from pump to gear)
Any Other Hoses you can get including the metal "cooling line" in front of the radiator. Get the cooling line mounting brackets as well. These hoses go between the gear, remote reservoir and cooling line. Take your digital camera and snap a shot of how it all connects before you take it all apart.
Good luck. This is easily the best upgrade that I have done on my 40 to date. Hard to believe, but it makes 40s even more fun to drive especially with larger tires.
Lash
sorry to hi-jack
You could use the head bolts to mount one above the alternator on the driver's side. The other option would be to use the motor mount bolts as an attachment point.
Where there's a welder, there's a way.
