FJ40 Fire
Renton, WA
My neighbor recently swapped a 1979 wiring harness into his 1976. He started the vehicle and was letting it idle while he moved a trailer. A fire started under the dash. He was able to get it extinguished with fairly minimal damage. I walked over to take a look and snapped these photos. Apparently an electric coil auxiliary heater caught fire. I don’t recall ever seeing an auxiliary electric coil heater in an FJ40. Question is:
Did Toyota ever install an auxiliary electric coil heater in FJ40’s? My guess is no and the following pictures are why:
View attachment 2755276View attachment 2755277
Other than a block heater, cant say ive seen electric resistance coils in a vehicle ever. And its for good reason. At 12-14Volts, the amperage required to create any perceivable change in temperature inside a vehicle is probably impossible unless you had a bank if tesla batteries and were towing a diesel generator!
"Apparently an electric coil auxiliary heater caught fire."
Can you point it out in the pictures because I can't see it.
There would be a resistor for the heater motor’s dual speed.
Wouldn't that be up on the blower and not where the fire was.
I wonder if the was some aftermarket electric heater put in the blower tube or above the heater core?
