FJ40 Engine Stalling/oddness any ideas?
Sterling, VA
Engine oddness? stalling. Any ideas?
Hi all,
I just aquired my 72 FJ40 and am new here, its been
less than a week and I've already got some hopefully simple issues/questions. :)
Here is whats happening,
72 FJ40 with 3 spd. and stock F engine.
Running normally it takes a bit of time to warm up, which seems normal.
Idling seems steady but occasionally stalls even when warm.
When warm I am driving, moreso in 2nd/3rd gears. Say doing 40mph or so, I start to slow down in 3rd gear and all of the sudden I start hearing some pretty harsh noises from the exhaust, I wouldn't say a backfire. But its loud, grumbly, and sounds like some not so loud popping. At that point the engine dies, I end up having to restart on the fly.
Same thing happens pretty much in 2nd gear as well, but the noise thing seems to be new. But it ends up dying on a clutch in deceleration, say when coming to a stop sign.
Is this just a low idle thing that happens to be killing the engine when I clutch in or something worse? Any ideas/suggestions?
Thanks for the help,
Rage
I had the same problem with my '71...while driving in Sterling.
Seriously though, my problem ended up being the points...so I replaced cap, rotor, wires and put a pertronix electronic igition in there. No more problem.
Check your exhaust system. Sometime the introduction of fresh air during deceleration will cause poping and backfiring.
Good luck.
The rumbling on engine braking is probably unburned fuel detonating in the hot exhaust manifold. At high manifold vacuum during engine braking the mix is too lean to ignite by spark. Things to consider would be idle mix and speed adjustments and possible manifold vacuum leaks. It doesn't sound ignition related to me.
