FJ40 door hinge bushings - brass
Is there a trick to getting these in? They seem too big.....I am sure I am just doing it wrong....any help would be appreciated... When I put them in the holes on the door hangers, the will not fit in between the existing things on the actual 40....its like the tops of the bushings are a little bit too thick.
Randy
Plenty left. Paypal $16.50 ($17.50 for CA buyers) cruiserbits@gmail.com.
Sent from my iPhone using IH8MUD
door hinge bushings
paypal and PM sent.
thanks
Roberto said:
getting ready to swap mine out from the sets I bought here but is there a writeup on how to do? these will fit rear amby doors as well correct?
R
If they are the plastic ones, they will probably fall out when you pull the pins and remove the doors. If not, just use a screwdriver and knock them out. The pin should be a tight fit. Do your paint a favor and install the top hinge pin upside down. The bushings will hold the pin in place.
