FJ40 Carbs - Compatible Years
Wake Forest, NC
Hi All -
I was looking to buy a back up Aisan carb (stock) for my 1970 FJ40. I know that different year FJ40s used carbs having slight differences. Specter Off Road (aka SOR) shows that carbs built between 9/69 to 12/74 are the same. So, if I buy a '72 or '73 carb it should fit my 1970. Is that correct or is there a better way to ensure that I buy a compatible carburetor?
Thanks,
Stoshzack
Have you considered a Trollhole or a carb from Racer65? I believe they both have carbs for a '70. '70 is pre-smog so these aftermarket carbs might be the ticket for you. I've had good luck with them personally and run them on my FJ40 and FJ60.
1970-74 are interchangeable. Slight variation in jetting. Trollhole carbs probably have more optimal jetting.
21100-60200 Aisin "A2" Carburetor Assembly, 9/69-12/70, changed to 21100-60201 for 12/70-9/71, changed to 21100-60202 for 10/71-9/72, changed to 21100-60203 for 9/72-2/73, changed to 21100-60204 for 2/73-9/73........ ETC.........
Update and FYI - I bought and rebuilt a 1973 which was not compatible with 1970 carb. The 1970 had a different vacuum hook up and a wire accelerator connection instead of the later linkage style connection. With that said, I have a rebuilt 1973 carb if anyone is interested.
Any chance you still have your carb?
