- Joined
- Jan 26, 2015
- Threads
- 14
- Messages
- 121
I think you are bleeding the brakes in the wrong order. Like Pete said, it should be left rear, right rear, right front, left front.
Interesting topic. I am going through the exact same issue on my 78. I replaced my front disc -rotors, pads, etc. about 2 years ago. Brakes have been fine. I cleaned up my truck and noticed a slight leak on one of my driver's side rear brake cylinders. I ordered two new cylinders for the driver's side rear. Replaced them and tried to bleed the system. I get full squirt up front but only drip in the rear. Lots of clean fluid, just not a heavy squirt when trying to bleed. This weekend, I replaced the other two wheel cylinders, passenger side. The brakes will not even stop the wheel in a free spin while up on jack stands. I have tried and tried to bleed but I can't get a good pedal or make the rears work. The front brakes are still Ok, just not as good as they were. I did RR, LR, RF, LF in that order.
After reading several threads on MUD, I am going to try to adjust the shoes tighter than I thought I needed to. I didn't replace lines on mine but fluid is clean and I haven't run the reservoir dry. Try, try again, I guess...![]()
Also never mentioned if they will pump up to a solid pedal ?
If it pumps up then I would agree that the shoes need adjusting. They should drag the drum just slighty, I like to do it with the tire on because the tightening of the lugs seems to change the drum a bit. Just saying cause I have adjusted shoes with tire off, then when wheel bolted up it changes the drag on the drum.
Another thing to try is to put some vise grips on the soft line for rear common off frame and see if pedal conditions change.
Great idea/detail on this bleed process, I'm currently out of town, but look forward to trying this when I get home. I've worked on brakes for over 40 years and NEVER had this much trouble bleeding them, I've spent probably 6 hours thus far, replaced ALL the brake parts, adjusted, and adjusted again etc. At any rate, I do have a question, I think you may be missing one small detail in your post. If you run a tube into the jar without the tube being submersed in fluid, you'll suck up more air and need to do a lot more pumping to get the fluid level up in the jar. At least until the fluid gets high enough to cover the end of the tube...or am I missing something? I've done similar tricks in the past with difficult bleeders and found that you need to make sure to submerse the tube into fluid first. The part I didn't do, which I just cant wait to try, is pump the living snot out of the brake pedal, I can't wait!I have just spent a month of Sundays on this exact issue; this is how I finally fixed it.
You need a 1 pint ball jar with two holes through the lid into which go 1/4 inch clear flex
lines about 18 inches each run to the bottom of the jar
Starting rear driver brake single bleeder, connect 1/4 inch tube and crack bleeder and
start engine. Then sieze that pedal with both hands and drive it to the floor and then quickly pull
it towards you as fast and hard as you can repeatedly watching as the res quickly empties
fill res asnd repeat until the pint jar is full. Repeat for rear passenger. For the fronts starting
with passenger connect both hoses and crack both bleeders then really get all your frustration
out on that pedal, all the pain and frustration these dam brakes have given you. When the jar
is full close the bleeders and move on to the drivers front and repeat.
This is will work, takes 15 minutes costs a couple bucks
Good luck all
Hi,Great idea/detail on this bleed process, I'm currently out of town, but look forward to trying this when I get home. I've worked on brakes for over 40 years and NEVER had this much trouble bleeding them, I've spent probably 6 hours thus far, replaced ALL the brake parts, adjusted, and adjusted again etc. At any rate, I do have a question, I think you may be missing one small detail in your post. If you run a tube into the jar without the tube being submersed in fluid, you'll suck up more air and need to do a lot more pumping to get the fluid level up in the jar. At least until the fluid gets high enough to cover the end of the tube...or am I missing something? I've done similar tricks in the past with difficult bleeders and found that you need to make sure to submerse the tube into fluid first. The part I didn't do, which I just cant wait to try, is pump the living snot out of the brake pedal, I can't wait!
Thanks everyone for the assist. installed a new master prior to all this. All the wheel cylinders are adjusted correctly, I adjusted both cylinders on each cprner to where they are draggin just a little bit, any more on any of them and they get too hot. I bled them the traditional way several times, then I used 2 different vacuum bleeders, a pressure bleeder which puts 10-14 PSI in the reservoir and pushes the fluid to each wheel cylinder, next I tried he IV-bag type setup at each wheel and I even tried back-bleeding them (this is how we do it on small airplanes) by pushing the fluid from each wheel cylinder to to the master. Finally I bought the fast bleeder valves. I was finally able to get an OK pedal, it still almost hits the floor but they work. a quick second pump and they're good. Ultimately, I think my best bet may be to get an OEM master and try that??I bled my brakes using a handheld vacuum pump.
That was awesome. No mess, didn't take long and I had a nice firm pedal
I could have written this same thread, right down to my wife's being burned out on brake pumping. I got a vacuum a bleeder from a friend and did not get success from that either. So, despite bleeding my system multiple times, I'm still needing to do one pump of the pedal in order to prevent the pedal from going all the way to the firewall. I don't know what to do other than buy more brake fluid or take the thing to Les Schwabe and have them do it (I don't plan that for now because I have admitting defeat). Let me know if you figure this out! FJ's must be hard to bleed.I have bleed brakes on just about every type vehicle. I've never had so much trouble as with my FJ40 this go round.
I replaced all the rear brake cylinders (2 each side). Also replaced the hard line that runs across the rear axle housing. Anyway, I have bled the brakes three different sessions, feeding three small bottles of fluid through the system and still the pedal sinks almost all the way down after the truck sits a few minutes. The system is really clean now and so I am recycling the fluid that comes out now. So it has been bleed, put that back in the reservoir, bleed.
I probably messed up in that I let the hard lines drip as I worked on both sides replacing the brake cylinders and getting the shoes back in place. So a lot of fluid came out of each line and am sure lots of air entered.
I started bleeding at the fartherist cylinder from the master cylinder. So I bled LR, RR, LF, RF. Kept going in that order several times, making sure to keep the master reservoir always full.
I am using DOT4, which I am sure you can use in place of DOT 3. Just not the other way around. DOT 4 has a higher boiling point.
I just ordered Russell 639560 speed bleeders (10mm x 1.0 thread) on Amazon. They will be in tomorrow. Am going to try those since the wife was getting bored doing the pedal pumping.
Any other tricks? I have heard people use some vacuum tool. Which one do people recommend?
Thanks for any feedback. Getting a bit frustrated.
