FJ40-BJ4X Tranny Knowledge Needed
Input shaft and bearing retainer are different on the F engine and B engine in the 40 series. The H engine is the same as F engine.
Also the H42 gearing is different in the H41. Most diesel have or possible all had the H41 four speed. All H55F shared the same gearing as the H41 of the same time persiod. Would hard to find if no impossible to find a B input shaft (which includes first gear) to fit an H42.
So if I can source an H55F I can make it work? Assume an H55F that was behind a 12HT still needs modifications?
I doubt this ever happens, but the whole plan has now radically changed. I can get a running B motor for free
there is a reason a running "B" engine is free
IMHO this is not worth the time or expense to use a "B" engine
3B would be different
And because we’re total noobs with regard to this world (thank god for you all!) this diversion was over before it had barely begun. We assumed it would be a bolt in and go option, but obviously not. So as soon as life allows we’re going to get a 2F and just see if it can move.
A 5 speed from a 12HT will fit a 2F, but will not fit the B series without swapping the input shaft to make it an H55B.
The B engine is very old tech and remarkably underpowered. They are also relatively hard to get parts for. The 3B, on the other hand is vastly improved. Compared to the B diesel, the 2F will feel like a V8.
that is what this forum is about
ask questions as you go
