FJ40 Antenna
Cedarburg, WI
I have read that most FJ40's did come with a factory installed antenna, but rather it was dealer installed. Does anyone know about this? I have a 1978 FJ40 and need to replace the antenna. I want an OEM part but need to know what to ask for. Thanks, JMP
ask for an antenna at the toyota dealership.......... you will get an OEM one
not sure... I was half way being an a$$... but I looked here
Antenna
from cool cruisers and they show a factory one as an option to buy... I would call CDAN before I bought from cool cruisers or your dealer... he is always the cheapest.
they came into the US with no radio or antenna, it wasport or dealer installed, this is the correct antenna and the correct location
Anyone have a shot of the correct routing (antenna cable) through the firewall? Mine goes through the same grommet the speedo cable is in, and seems like it should be elsewhere?
I also just got the upper bracket at Toyota with no problem.
Can you supply any of the part numbers? Thanks, JMP
JMP,
Some variations exist on the location. Your install depends on the "look" you want to achieve.
While USA-dealers usually installed the radios, optionally, some OEM radio kits were later owner-installed.
Some models for World Market, non-USA, 7901-8612, came with factory captive-weld nuts in the cabin. Most LHD trucks had the antenna mounted to the RH passenger side, although I have seen an '83 LHD with the antenna factory mounts on the LH driver side. This one was mounted higher, similar to the CCOT demo photo.
Those trucks with captive nuts had antenna mounts between the kick vent and the A-pillar strengthening rib. Likely this was to better protect the antenna, allow adjustment from within the cab, and routed the cable within the interior. Also some of the original antennas had original chrome bases.
Today, twenty-five years later, a lot of factory variations, superceded parts, and aftermarket crap has come and gone. I hope even the most strident afficianado would not criticize you for your antenna mounted within the above parameters. Remember, even the dealers themselves f****d up, much like they continue to do so today!!!
JMP,
Today, twenty-five years later, a lot of factory variations, superceded parts, and aftermarket **** has come and gone. I hope even the most strident afficianado would not criticize you for your antenna mounted within the above parameters. Remember, even the dealers themselves f****d up, much like they continue to do so today!!!
Thanks for the info. My 78 has an antenna that was mounted "at purchase", but the metal antenna rod has been broken off. My intent, once I find an OEM/Dealer antenna is to leave the mounting hardware where it is and simply replace the metal rod. Your info is very usefull and if you or others happen to have the metal antenna rods, please let me know. JMP
if you bought a radio kit from Toyota back in the day, it came with a templet on where to install the antenna.......not that it had to be followed..
so pimp did all those trucks ship over the pond with the radio delete tab in them..... and you had to add a radio as an option...
thats my understanding, but ya just never really know...
When I had my body redone we welded up the POs hack job holes for the antenna. Does anyone if there is a system out there with new technology to just go antenna less?
I have specific mount areas on the R side of my '78 for the factory antenna, however, one of the PO's(there were two) decided to drill a hole thru the cowl for a "firestick" type shorty antenna. I have an OEM antenna and plan one installing it some day. I can post up a pic of the mount point on my '78 if you like.o_O
If I am not able to go antenna less, I would love to see a picture for proper mounting location. My hope is that if I can get away without an external antenna, I don't have to worry about it getting caught on something and drilling unnecessary holes.
Curious what you mean by specific mount areas on the right side for the factory antenna? while I don't have a 78 I have a few cowls from 78s. didn't see a specific mounting marks.
Will try and get a picture up soon
