Fj40 1979 front axles problems?(Help)?
I just swap back the 1979 axle housing this morning with the old knuckle I'm going to take it to my friend rac to see the camber &toe will see what #s we're dealing with
First of all, there is something very strange about how that front spring is drooping. It looks like a broken leaf from the pic.
Second , with that much droop, I’d expect to see more angle between the front pinion and the driveshaft, unless you have a cut and turned axle.
So looking at that printout.. the wheel you were concerned about (the right) has Camber almost within specification.. Have you got any play in the king pin bearings at all? Were the wheel bearings in good shape when measured. I'm not entirely sure there's anything left to do, give it a 1000klms and assess tyre wear?
No play on the king pin bearing I changed them last month thinking that it was the problem but no 🎲😔
I'm not entirely sure there's even a problem. I'm not an expert at reading the alignment sheet you posted.. but it doesn't seem to have any great issue? Your castor is out a bit but wedges would fix that.
Busted spring----
how does a broken spring make the wheel tilt out as seen in the pic in post #6?
unless it is an optical illusion in the pic.
The picture does seem to be perhaps deceiving.. I've looked at it a few times and cant make my mind up. The jack is under it, the steering is slightly turned in, the guard is not a great point of reference, the other wheel cannot be seen. Its hard to draw any conclusion from this picture.
I just ordered some wedeges to fix the castor thanks again 😀
