Hi to everyone, im restoring my fj40 1972, can anybody help me with the lights front and rear, I need to know which type of lights it use, there are different types.
PLEASE HELP
PLEASE HELP
Most of the people here on IH8MUD have United States market vehicles, built to standards required by U.S. regulations.You will have to be more specific. Which specific lights are you talking about and post some pictures so we can physically see what you are talking about.
Thank you. I believe those Ines are not the originals one.. they make some holes to hole them .
Use the values in this THREAD as a starting point and adjust for whatever lights you have. If you have an OEM style flasher you will need approximately 50 Watts of power on each side, right and left, for the turn signals to work. That means the front and rear of one side must equal approximately 50 Watts. If you go with LED lights you will need a load resistor or an electronic flasher.
According to this CHART and the frame number you gave us, your 40 was built in July or August of '72.
forum.ih8mud.com
Ei Johnny thanks for you answer, I have found some photos that I think they are the same as mines.Tail lights.... in this thread you can see the size they should be ... and style
Dobster's 1965 FJ40 Soft Top Resto
Excellent - From what I can see the cross member seems to be shorter and the rear lights set up attached to it. I went and took some more photos of mine and had a chat with the Panel Beater. He thinks the cross member attached is that it is orginal. All the rivets and bolts are all correct...forum.ih8mud.com
I would like to make a good work . I prefer the round ones instead the rectangular ones.Yes I think yours were cut out larger.... however... those original lights that are supposed to be there are like hens teeth
It will be VERY hard to find the correct lights
May want to find a good alternative to fill the spot ... how close to stock form are you wanting to go?
