I'm going to disagree, based on the number of threads that regularly appear regarding caster correction methods, drive line vibration, and poor handling after installing lifts.
They can be done simply, or if that is the choice, a lot of $$$$ can be spent. Yesterday was test drive day for two "new" to the fleet rigs. They were both bought right, factory locked, but, not the prettiest girls at the dance, checkered history, no repair receipts, etc.
Standard builds, call Cruiser Outfitters, order springs and shocks, then we make the rest. In this case we had a lot going on, so also ordered plates, instead of doing washer mod. The blue one has heavy rear and J front springs, the tan has Js with 1.25" front spacers, both have L shocks. Both have craigslist 17x7.5" Toyota wheels w/ 1" spacers and 37"s, the blue has Kanati, the tan Cooper STT.
I drew the short straw, had to drive the blue one, at 262K miles, is solid, tight, goes right down the road and trail. Still has a few issues, some burned out bulbs, setting a couple of O2 sensor codes, so will swap the front one, needs an A/C compressor, slight slack throttle shaft growl, so will try changing phase. Is running slightly warmer than we would like, so before summer, will swap the relatively new copper for an aluminum radiator. Waiting on a couple of pallets from 4x4 Labs and they will be capable trail rigs, as intended.
It depends on intended use, these will never win at the show and shine, have no pedigree,, don't care. Likely are not done "right" by Mud standard,, don't care. My prediction, will see a bunch of the southwest trails, haul a bunch of tools and get a lot of work done, as intended.
