fj cruiser wheels.......
Scottsdale Arizona
will fj cruiser wheels fit on an 82 toyota truck?? or better yet is there a list of wheels that will fix the 82??
tundra? taco? ect???
We need some more info, ifs rear end or stock, do you have ifs front hubs or spacers?
stock 82 straight front axle no spacers with manuel hubs
Not a chance. I'll bet the FJC wheels are 4.5" backspacing IIRC. Anything over 3.75" will rub on the tire-rod ends.
You will need 1.5" spacers or swap over a IFS hub.
On my '85 I run fj cruiser wheels with 1.5" spacers on all 4 corners
dam IFS lol real rigs have a straight front axle............:)
What we're talking about with IFS, is the rear axle is 3" wider than the earlier SA axle trucks, and the hubs that the brake rotors attach to can be swapped onto the SA rigs for a 3" wider front end.
ok .. another questions about how much are 15 inch steel rims 9 inch wide? ballpark??
Last I heard about chevy wheels on toyota's is you need to bore the center hole out some
Had the guy measure its 4.5 center hole and 5.5 stud across to stud so that will fit the yota (same as my fj40 which I could swap wheels with)
so if I find 3.75 and under will work?? I found some 1999 taco wheels They at least should work on the rear, correct??
