Fj Buggy: V8,Rear steer,Toy axles
Discussion in 'HardCore Corner' started by mpistolpj, May 23, 2008.
  1. mpistolpj
    mpistolpj
    85
    May 1, 2008
    mocksville, nc
    here is my newest rear steer buildup at the shop.. Trying to stay somewhat cruiser....
    Build up here...Blank page
  2. bandy rooster
    bandy rooster
    1,935
    3
    Aug 11, 2005
    Sunny South
    care to divulge in some more specs?
    whats after the trans?
  3. mpistolpj
    mpistolpj
    85
    May 1, 2008
    mocksville, nc
    specs
    2006 5.3 chevy to a turbo 350 trans to a 203 low range gear box to a fj60 t case... spit to front and rear steering toyota land cruiser axles....If i can get out of rookie territory i have more pics to show....
  4. Isotel
    Isotel
    4,061
    Media:
    5
    Albums:
    1
    40
    Sep 29, 2003
    Crawlorado.com
    Looks dam good! Only Question would be why you would use an FJ60 t-case??
    from your website it looks like you have done a bunch of the rear steer toy axles, How are they holding up?
  5. bandy rooster
    bandy rooster
    1,935
    3
    Aug 11, 2005
    Sunny South
    i assumed the toy case because he was sticking to cruiser axles?
  6. mpistolpj
    mpistolpj
    85
    May 1, 2008
    mocksville, nc
    case
    It is very strong and keeps everything to one side... Plus it is relitively lite...
  7. R.K.
    R.K.
    1,442
    156
    Feb 26, 2002
    Roxboro, NC
    Looking good PJ! Keep the pics coming. I can't wait to see how this one turns out.
  8. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,346
    1,370
    Apr 4, 2003
    Panamá
    I thought you only recomend it for light buggys .. ?
  9. mpistolpj
    mpistolpj
    85
    May 1, 2008
    mocksville, nc
    t case
    It is a very strong t case... other things should let go before it does... I have used fj40 cases in some 4cyl rear steer builds but i am confident in the 60 case for the v8 application... Any one who has taken one apart can vouch for the strength... i am hoping this rig will come in under 3500 lbs...
  10. Tapage
    23,346
    1,370
    Apr 4, 2003
    Panamá
    There are plenty V8 engines mated to a Toy tranny and t-case without problems .. but the important point it's how much powa get the V8 .. ?
  11. Eskimo
    Eskimo SILVER Star
    1,358
    Sep 6, 2002
    Danville, PA
    It's the same engine I'm running :D
  12. mpistolpj
    mpistolpj
    85
    May 1, 2008
    mocksville, nc
    power
    From what i have seen that should be plenty of power.. considering i am used to around 90 hp...
  13. mookie
    mookie
    1,727
    3
    Oct 18, 2004
    West Georgia
    what are you using for your rear steer axle? surely not mini-truck....60 series or 80? and what size tires? looks cool!
  14. mpistolpj
    mpistolpj
    85
    May 1, 2008
    mocksville, nc
    fj 60 axles front and rear... with 4.88's and longs all the way around...
  15. Tapage
    23,346
    1,370
    Apr 4, 2003
    Panamá
    :eek:
    I need to see that !
  16. LC_Hamma
    LC_Hamma The Anti-Leafer
    2,675
    25
    Nov 11, 2002
    Dallas, Georgia
    Those 39" Iroks?
    :cheers: to you for wanting to spend yer wheelin time trail-fixin those axles. How them knuckles holdin up? Did I see a 3 spd tcase on yer web page w/o some type of reinforcing "saver" behind a V-8?
  17. R.K.
    R.K.
    1,442
    156
    Feb 26, 2002
    Roxboro, NC
    Nope, they are 42" IROKs on the new buggy. The 3-speed t-case is in a buggy (green FJ40 hood) with a 22R/mini truck 5-speed/mini truck t-case/FJ40 t-case. It also has 42" IROKs. Then there is another buggy (blue FJ40 hood) with the same drivetrain and 39" IROKs.
    PJ's current buggy with the 22R and 42s has held up pretty well, and it gets wheeled often.
    The FJ steering axles should hold up with the V8. My front axle has held up fine with a V8 and 39" IROKs for 2 years, and now 42" IROKs. PJ has 30 spline Longs front and rear. I have them in my front axle, as well as ARP knuckle and hub studs.
  18. mookie
    mookie
    1,727
    3
    Oct 18, 2004
    West Georgia
    how much do you think this rig is going to weigh? and i'm guessing that your running that front axle upside down in the back? does that make the 3rd a high pinion? isn't that supposed to be weak in a rear application? and do you cut and rotate the knuckle balls 180 degrees?
  19. mpistolpj
    mpistolpj
    85
    May 1, 2008
    mocksville, nc
    R.K. is right... i do try to wheel about every other weekend somewhere with My first buggy that has been done for almost 2 years.. that is a lot of wheeling... it has held up well.. My only carnage to date is Ring and pinion... in the rear.. and no powdercoat left on the outside hoops. do to rolls and flops... It is super light 2800lbs and runs the 22r on propane with rear steer and 42's.. yes it has a 3 speed case with no t case saver... I have not had any problems... But the torque of a 4cyl is why.... I am sure people will attest that i am not super easy on it and that is goes where any other purpose built buggy goes... and maybe then some... With a 3rd place finish at Uwharrie cross race a couple weeks ago. I am real happy with the platform.. I built one for A customer down in Florida... basically the same setup with alot nicer creature comforts.. he is running 39.5's, and it really works also...
    WIth that said the extra strength of the Fj60 t case over the 3 speed case should be enough to keep things together with the v8... I am hoping that my weak link will be 30 spline longs...
  20. Tapage
    23,346
    1,370
    Apr 4, 2003
    Panamá
    Dude .. how much runs you calculate over your king pin and wheel bearings with those Iroks 42" . ?
    I know it all depend on the terrain and the skiny pedal .... but it's just to make me an idea ..
