fj-80 project
Asheville NC
I have a 1996 FJ-80 that I have been collecting parts for. I am about ready to start on in about 5 months. I have a few question. I have 39" iroks that I want to run. Should I use 5.29 gears? I want to keep it low so I plan on cutting the fenders quit a bit. I think I am going to 3 link the front as well. Any comments, opinions, pics, and ideas are welcome. It has factory e-lockers hope they hold up. I plan on buying the longfield front axle kit and just testing the rear stock shafts to see what happens.
A 94 is a FZJ80 91 & 92 are FJ80's
E-lockers are not a good match with 39's since you will be in there anyway to regear you should swap 3rds, short side axle shafts and wiring with an unlocked truck and go with ARB lockers.
there are several threads about 3 link setups here is one of them
https://forum.ih8mud.com/showthread.php?t=122453
E-locker
I have heard that from several people. Why is the e-locker weak? I saw that action Jackson ran a factory e-locker wit 40's. Wonder if he has braking problems? I have a front axle that is open and one that is locked I am trying to decide what to do. Hey I'm up here in asheville north carolina is there a cruiser club around our area?
The way the e-locker is setup it uses the short side axle shaft as part of the locker, this works just fine with stock and a bit larger tires but those with very large tires that wheel hard sometimes find an axle shaft twisted, unfortunately this prevents you from removing the 3rd.
search there are several threads with pictures of what happens.
how far is Asheville from Atlanta? there is the Georgia cruisers
http://www.georgiacruisers.org/
I work weeknights so I very rarely go to their meetings, not sure what is going on with them right now.
And several upstate cruisers in North Carolina.
lockers
OK that helps a lot. Thank you guys for all the info. It is a lot better here than on pirate I usually just get smart ass remarks there instead of help. I think I am going to try and run the e-lockers for now. I have the open third if it doesn't work. Also I am going to run the axles in a lighter vehicle that a cruiser so I believe they will hold up.? I hope.
