FJ 40 blinker relay
Idaho
The blinker works fine for driver side. For the passenger side, it blinks once and then nothing. Any ideas on if I can fix it?
I didn't think there was a flasher for either side. 1 flasher for turn signals and 1 flasher for hazards, unless I'm thinking of a different year.
Also check to make sure you have good bulbs. Just had same issue ending up being the bulb. Start with the simple.
good connections of the bulb
if one side blinks and flashes normal at least , your grey silver 81980-30040 flasher box does indeed work
start simple and low cost , change out ALL hazard function bulbs at one time , inspect the sockets them self's inside for rust and corrosion , make darn sure you don't forget to apply a generous amount of full synthetic Di-electric grease to both deep inside the empty socked and wet down the bulbs sockets parts too for good measure , then preform your full function test again
to see whats what about all that ............
good luck
Some FJ40s had only one flasher (for both the turn signals and hazards), others had two (one for the turn signals and one for the hazards).
Do all bulbs work when the hazards are on?
