Fixed that blasted V8 manifold ticking noise quick and cheap!
Hi all,
sorry if I connect to this old thread but since I also suspect a leak of exhaust gas from the exhaust manifolds, I wanted to know from LC2001 if I can do this test using only compressed air and soapy water
in particular I would like to know how to introduce compressed air into the engine
thank you
Giacomo
Hi all,
thank you
Giacomo
I made up a fitting (plug) for my compressed air hose with tape wrap around it. Then plugged tail pipe with taped fitting/air hose. Then dial up the air pressure a bit. I then turn the crank CW so that all valve at cylinder where I'm inspecting exhaust manifold are closed. I listen for air leak and spray soapy water on headers, watching for bubbles.
I build a cheap smoke machine using compressed air, new paint can, and charcoal. Pretty simple, and works well for intake and exhaust related leaks.
I built one using mineral oil for smoke, tried large color smoke bombs form 4 July also. Made a ton of smoke. But smoke dissipated before reaching exhaust crack in headers.
So I then just ran the compressed air and spay bottle with soapy water for bubbles. That's when I finally found the cracked header. Accord to service history it was an OEM replacement header Dealership installed, that was leaking.
1st time I know of replacement Toyota exhaust header cracking at wield, just like factory do. May have been old stock!
Thank you 2001LC
to have all the valves at cylinder where I'm inspecting exhaust manifold are closed, must the piston be at its lowest point ?
Giacomo
Well yes and no. On compression stroke, all valve are close at bottom and on the way up.
What I did was turn the crank with socket wrench until I saw air bubbles forming at header flange. It used sound first, to help isolate area. Then kept spraying soapy water on area. Doing this as I turned the crank.
Thank you 2001LC
so if I understand correctly, I have to continually turn the crankshaft and see if there is a leak ....
for connection with the cylinder to be tested, have you used any special tools ?
Giacomo
Yes, you keep turning crank slowly. I use a 1/2 drive ratchet wrench with 22MM (IIRC) socket. You start by determining which side has the tick.
You could find top dead center on compression stroke of #1. Than mark crank pulley each position based on firing order. But by the time you do that, you could be done.
A note: So often we get a loose spark plug. This too will sound like exhaust manifold leak.
Thank you
did you use any special tool to introduce the compressed air into the cylinder to be tested ?
Giacomo
I pressurizing the exhaust system from tail pipe. Just wrap duct tape around compressed air hose, making a tight fit into tail pipe.
OK so anybody with an early model 100 series,tundara or LX UZ engine knows their only real weakness is the factory manifolds which almost are 100% guaranteed to crack st some point and give you the darn annoying ticking noise.
This was my quick fix and it worked a treat. Ticking noise gone and it should last quite a while until i eventually replace out with headers and upgraded exhaust. Most people know this is a hard job in terms of vehicle access and outright expensive if you get a shop to do it for you.
Snake oil does work from time to time but before the naysayers jump on im under no illusion that it probably wont last forever but i dont need it to, i just cant stand the ticking! :)
So how long did the temporary fix hold up?
I just failed inspection for 1) muffler/exhaust (I have OEM in my garage waiting to go on) and 2) exhaust header leak. Looks like I need a fix that'll last for a few hours in order to get that sticker! 🤣
